1 - 12 of 12 Posts
Anyone know the size of the allen wrench you need to pull the crankshaft accessing cover off? I need the size so i can get the right tool before I adjust the valves.
I used the head of a bolt and double nutted the other end. Cheap and works awesome.
I am pretty sure its 14mm. mind you i drank alot of beer :eek:when i did my valves.
Crank, its bigger than the timing mark one.
I was talking about the cover before you get to the crankshaft.
size12 said:
My bad it is 14mm the makings on my tool are half worn :chair:
Yea thanks now after I bought the wrong tool first. :mad:
1 - 12 of 12 Posts
