1 - 20 of 22 Posts
Who out there is running a Cuervo +1 Head or any +1 Head on their Raptor 700. Would like you to share what combo of Cam, Compression Piston, Throttle Body and Intake your running to better help me decide if it can easily reach the desired hp I’m looking for.
What is your desired HP?
+1 Cuervo head
+2 throttle body
+5 stroker crank
HDD5050 cam
11:1 CP piston, decked .040in
Sling shot lock out
Head studs
Crank bearing support plate
72-74 HP, 55-57 torque at sea level, 92 pump gas.
Discussion Starter #5
+1 Cuervo head
+2 throttle body
+5 stroker crank
HDD5050 cam
Sling shot lock out
Head studs
Stock intake tube???
FCI duh
FCI intake and stock, port matched rubber manifold.
Discussion Starter #9
138879
Wondering how Brandon is achieving this with much cheaper builds! Makes me feel as though a + 1 head with a 14:1 piston in the same setup listed in the pic should be at least 75hp
You should do it and find out!
Or next best option, call Cuervo and ask him. And call HPS and ask him about your build too. Get it right from the horses mouth.
I can guarantee Cuervo builds make more power than HPS. HPS has been challenged to race Cuervo many times and always backed down.
Sure, you can take a stock motor and add 14:1 and make power with race gas, but it's not the right way.
70/53.5 SAE, look at the bottom end lost. And can you get a constant 93 octane. If you got to mix race gas, may as well get the 14:1
Discussion Starter #13
As far as race gas I agree! I’d go full high compression and run 110 before I mixed anything! But it’s still amazing how he’s making that that much hp with the stock intake tube and on 93
Stock intake tube isn't that bad with a good filter.
Stock stroke, stock bore and stock valves can make some good power with a little more compression and TB. But again, how many people have pump 93 available? (no "T" not you)
Is 93 not common where you are??
I'm in Washington state and max at the pump is 92. I ride sand dunes in Oregon and most places is 92. Once and a while I can find 93. Also travel to Glamis thru Arazona, Nevada and California and always look for 93, but mostly 92.
What is available around the country?
Discussion Starter #18
Is 93 ok to run with a 12:1 piston?
No 93 around here anymore, just 91. E85 is pretty common though
I'm in Va, and 93 is everywhere, and has been for as long as I can remember(I'm 42).
I've also traveled the country alot personally, and I used to drive a tractor trailer, 40 states, and I watched gas prices out of curiosity(in turn paying attention to octane and costs).
93 is pretty common on the east coast. As you go west/southwest, I did notice the highest octane drop to 92 and 91. Which I assume just depends on what the closest refinery makes. Why a point or two less, I have no idea...but our higher octane east coast 93(north east excluded) is cheaper than the lower octane in most of the rest of the country...but it's all garbage ethonal anymore, lol.
1 - 20 of 22 Posts
