Anyone out there make aluminum dune/drag tanks for the 660? It is for a custom R1 Raptor. The stock tank does not have enough clearance for the intake manifold. So the new tank just needs to be literally about 3/4" shallower, all else can be the same as a stock tank. The bottom of the tank could even be flat.
It does not need to hold a whole lot. The stock tank holds 2.9 gallons, I'd be fine with 2 or less. I would also like to incorporate a in-tank fuel pump which means the tank might need to be sumped. I have a spare 660 tank and in-tank pump I can send to whoever also.
I will not be running plastics so it does not need to be able to fit under the stock plastics. This is a pretty simple tank to build IMO.
Let me know who can do this, thanks!
Check with some of the guys in the Hybrids and conversion section that have done it.
Bump
Bump?
