These are 12.5 JE pistons with larger valve pockets so you can run a stage 3 cam and big valves. I had these pistons custom built. Im only getting 4 of them this week. So give me a call and I will hold one for you.
Sand Demon Motorsports
1 530 832 9696
Is there any way to run pump gas with a 12.5 piston? Like two head gaskets or something? :crazy: or should you just get a 11.1 piston? Can you have a 11.1 with large valves for a stage three cam? Sorry about all teh questions ::) Just getting knowledge for when I go the next big step! :grin_nod:
I would just go with the 11-1 piston. I also have those in stock ready to be shipped.
1 530 832 9696
sparky did you loose myy pm? anyway i have been running a 12.5 je and a stage 3 web cam for about 15 hrs (hard hrs) and have not had a problem at all with it. when will i see the problem you think? i have had it rapped out in 3rd gear and never seen a problem yet. Should i worry if i have already put somany hrs on it?
Capt
I would bet the squish is a bit to much if it clears fine. I run the squish down to .042 and then the web 3 wont clear the exhaust valve cutouts in the stock JE piston. That might be why your not over 60 with that build.
1 530 832 9696
Well you only have 3 because I hope one of those is for me. :wootwoot:
