While I'm waiting for my parts to be finished I'm working on another small project with the rear suspension.
Some take the linkage shackle and flip it to get the rear end lowered (which is bad if you bottom out the suspension because it binds components up which can break things). Basically I'm taking the same shackle and flipping it, but notching out the problem areas where clearnce is an issue. The Linkage I'm working on is made from scratch and is made from steel that is twice as thick as what was on there before. I'll be super low to the ground, but in turn I get to crank up my preload, sag control,..(or whatever most prefer to call it) to compensate for it being too low. since I had to completely crank my pre-load all the way down to stay low to the ground where I liked it, I would bottom out easily on bigger jumps. Now that I've lowered it I'm able to crank the preload up; which would put me as the same ride height as before with the benefit of not bottoming out,..with actually a hair more travel as well. The leverage ratio was not changed or changed very little!
Its basically what elka sells (their linkage kit) for $250 bucks! I'll take pics and keep ya'all posted on the progress..
