Hi guys I just wante to see your pictures of your cutted fenders cause i'm thinking about cutting mines. And also what tools did you used. Thx!
I would like a nice " MX " cut, far up front with a lil'bit left on the rear. Maybe put some scoops on it as wellI just used a razor blade on mine. All I did was use one of the razors where it clicks up and you keep breaking it to get an new section. Just mask off where you want to cut, and start going at it with the blade. It took about three passes on the plastic to cut all the way through, but its a nice clean cut. Make sure after every cut or two to break the razor to a new section (or change the blade) to make sure its as sharp as it can be. Once you are done cutting, you just use a fine sandpaper to take off the rough edge, then you can take a torch to round the edges and return the original shine and get a professional look. How far down are you wanting to take them?
Nice cut SPIDER!![]()
Cutting wheel on a drimle.
