Hey guys
The bike has BB kit, Ported head, WK 54mm, Pink injector and supporting mods
After break-in the bike i noticed that cutting out on high RPM...Adjust the TPS ( 0.705 OHM's ) then took to the dyno and we find that it cut out from 6000-7000RPM on 4th and 5th gear...remove the reverse limiter still no luck
Here what i noticed :-
1- Even after i adjust the TPS i never saw 0% while the bike on the idle..is that fine? should i check the TPS took from the 0.705 to full throttle to check if it is fine or it doesn't matter?
2- Each time i change the sparkplug and after 2-3 WOT rans it ran perfect ( no cut out ) after that the damn back out comeback again WTF!!!!
What do u think ?
What do u think ?
