No, it is not. The OEM cylinder has a sleeve. Most of the applications I've seen with OEM plating is where the cylinder is one piece of cast aluminum.
So installing a oversize piston would only require a standard bore and hone.
How deep can these sleeves be bored out?
Last I knew the warrior took up to .080 over, or 2mm.
So yes a bore will hone will do the trick.
