Been working on installing my CP piston for a few days off and on. When I had the head off, the smaller of the two pins fell out. How does it go back in? I have my motor pretty much together. I assume the rounded in pushes on the lobe of the other pin sitting next to it..
Pin goes in the hole in the cam lobe with the rounded end up and the flat part on the side facing towards the cam gear side of the cam, slide the "barbell" shaft into the middle of the cam until it fully engages to the pin and then put the lever plate on the end of the cam thats held on by two bolts. Afterwards work the cam lever back and forth to make sure the pin moves up and down and theres no binding.
I ment to thank you earlier, but thank you for the fast response. It was spot on and just what I needed. I have my Raptor back together, and after a few more heat cycles I hope it will be good to go!!:cool:
Thanks man. I "D-blocked" the quote off someone else on a lacol 4x4 forum.
