I installed my temp guage on the upper rad hose by the head....not sure if it was supposed to go there or closer to the water pump....which way does the coolant flow on these bad boys....i should know this:rolleyes:
Looks good to me. I thought from there the coolant went back to the radiator. :thumbsup:
Thats what I thought but I wasn't sure....just want to make sure I'm getting an accurate reading:D
Yea you did it right. That way your reading the engine's water temp. That hose as close to the head will give you the closest reading of the engines operating temp.
If you put it in the lower hose then it would read much cooler and wouldnt really show overheating until it is to late.
I have had my ESR temp gauge for a couple years and it is still going strong.
Normal temps is 180-200 when riding. The fan doesnt kick on until it gets around 225 deg.
Mine hasn't gone over 205 yet:D I've never heard my fan yet
Coolant goes in the top and out the bottom.
