1 - 20 of 43 Posts
How big of a difference between the cp 11.5 and the 11.1
Pistons is there? How big of a drop in compression is there?
Is it noticeable in power? The reason I am asking is that I seem
To be having some detonation issues with a brand new 11.5 and
Pump premium 91, and was wondering if it would be worth while changing
To a 11.1 instead. All I can get in town for fuel is 91.
11.5:1 should be good with pump gas. Are you sure you don't have a lean condition contributing to the problem?
Nate
Alba Racing
Thicker head gasket might help if you wanna save some cash. I don't know how much a .5 compression makes but I would think you could get a thicker gasket cheaper then a new piston.
Detonation on our tech piston is very rare. It is usually from poor fuel or poor fuel delivery. I'd check both of those first.
Steve
I got a hc3 in it. I am going to try a new pcv first . I just don't want to have to worry about fuel as all I can get is 91 . I got to make this quad 91 compatible.
Banned
The 11.5:1 is the highest compression you can run on pump gas so your good. The .5 to the compression difference from the 11:1 to the 11.5:1 shouldn't be the issue, check out what Steve said....
We have 93 here how many points will octain booster raise the 91 to? I always thought it was bs never tried I run good Pump fuel :lol: I got it out the pump
I always though at 11.5 you should run 93 octane or 91 with a booster additive,if you can get a good one.
Just a 78HP trail bike
99.9% of octane boosters dont do a thing but empty your wallet.
That's why I never used any if I needed more than pump I either got 100 or 110. It's pretty easy to get here.
Sure hope this piston works out to be 91 friendly or it has to come out or maybe even grind a bit of the top lol.
You should be fine with 11.5 compression. I run a cp 12.1 on pump gas at 1900 ft of elevation. What is the elevation up your way??
Once you get the PCV in there and tuned up you should be good to go.
My guess is you need to have it tuned its probably lean.
Discussion Starter · #18 ·
Well I went with a pcv a tried a couple different maps and am still having detonate issues , I got a hold of some 94 fuel and that helped quite a bit but did nit cure it 100%. It's happening mid rpm range with a load on , not sure what to do. Not sure if the difference in the 11.1 piston would be worth the change out or not. What is stock comp ratio ?
Ya Steve I don't know why it's running like this, I got your map in there now and running some 94 and it is a lot better than last week but still not perfect. Would adding one more base gasket be about the same as changing pistons out to the 11.1 ? I am not worried about the cost of an other piston but don't want to go 11.1 if it's not going to make that much of a difference.
1 - 20 of 43 Posts
