1 - 2 of 2 Posts
so until now when i connected my pc to the PCV while the quad is running i always saw the data of duty and fuel adj. by their original gauge, today when connected it showed 0 all the way, with and without throttle opened.
and then when i switched them (instead of duty and fuel adj. i replaced it to duty 1 and fuel adj. 1) and then it showed data and the adjustments, is it simply something in the software or does it changes something?
i dident messed with the PCV options what so ever.
The fuel adjsutment on the right is a reflection of fuel change that is happening within the map. The duty cycle is how many times the injector is spraying per rev of the crank. Those are viewable channels only. If you right mouse click on those guages it will give you aditional viewable options.
1 - 2 of 2 Posts
