1 - 2 of 2 Posts
Hi, I was recently checking my ball bearings in my hub to see what was causing a tire wiggle when driving. Apon doing this I came across a larger problem, when I had the brake caliper off the disc my cousin not knowing squeezed my front brake lever. Now the caliper is locked up. How do I get it apart to put it back onto the disc? thanks!
Can't you just put a small Flathead in between the caliper and pad?
1 - 2 of 2 Posts
