I have a stock 2005 660. I have to let the clutch lever all the way out before it moves. Is this a free play issue or do I need a clutch?
Make sure there is some free play in the clutch cable...........Try adjusting it, if you can adjust the free play out then you should be ok. If you find the clutch slipping in 5th or on a holeshot then it may be time to put in a new clutch.
