I was adding handguards yesterday and had to adjust the brake line angle, I just broke the bolt loose so I could adjust it, I didn't remove it. A little brake fluid did seep out. My question is do I need to bleed the brakes after this? Thanks for any help.
(see attached pic for which bolt it was.)
#327 "After Hours"
Hows the brakes feel? If they're spongy and feel like airs in it then yes. If not, let it ride.
Ok, They feel good so I guess I'll just let um go. I just wanted to make sure there wouldn't be an air bubble in the lines or something that could cause a problem down the road... probably just when I need them...
