petcock to tank seal the seal inside the petcock... the 2 covers on shifter side engine you take off to service the vavles to check tdc of piston and to turn it. the exhuast and intake tappet covers. Should gas are oil be applyies to any of the following seals before torque down?????? Also whats best to lube the fuel line to slide onto the petcock and carb.
