I have now used Dobeck, Noss Boss and PCIII on 700R's that was one my dyno.
Here is the part no one ever tells you about the real difference between these units.
The Dobeck and Noss Boss works, but they have SERIOUS drawbacks. As mentioned, one of the biggest drawbacks, is the time it takes to have it set up correctly. I found these units to be very finicky and less than a 1mm turn on the accelerator pump can mean the gain or loss of nearly 3HP. The other major drawback with these units are their design and the way they fire the fuel injector.
These units connect in parallel with the injector and the stock EFI unit. Both the Dobeck and the stock EFI fire the injector simultaneously. This is fine for most cases under acceleration. When you need more fuel, the Dobeck fires the injector for a longer period, allowing more fuel to get into the motor, BUT, when the stock EFI is already adding to much fuel, the Dobeck or other parallel connection devices cannot make the injector signal less. You cannot make the fuel delivery leaner with a Dobeck or Noss Boss if the stock EFI is adding to much fuel
If you look at the dyno graph VelociRaptor posted, you can see the problem immediately. Just below 4000 RPM and again at 5300 RPM onwards you see a rich mixture. With a bit more time on the dyno, it might be possible to address the mixture in some areas, but they might not be able to fix it below 4000 RPM. Below 4000 RPM the mixture plays a major role in power output, and it is critical to get it perfect. This raptor can make much better low down torque if they sort that very rich condition out.
Also, keep in mind that this dyno graph has smoothed out the A/F ratio and it is quite small in size. If you zoom into the A/F mixture graph, you will be shocked to see how badly the results actually are.
The PCIII connects to the fuel injector in series with the stock EFI. This allows the PCIII to increase and decrease fuel delivery. It does not compete with the stock EFI signal at the injector. The PCIII has full control.
The Dobeck has 4 settings. Idle, 2 pots for mixture and one pot for accelerator pump. It will not allow you to target specific RPM's and fix just the problem area, You make compromises with these units and are forced to use averages to fix problems. When using average setting, you can fix the problem, but in doing so, create problems where there where none to start with.
The PCIII on the other hand can be set up for each 250 RPM, plus it has throttle position sensing, where the Dobeck and Noss Boss units don't.
Now to the biggest thing, most people forget when they look at the dyno graph. The posted graph seems fine, but this is only one very small part of the whole story.
That graph only shows that the ratio is ok for acceleration with full throttle. 95% of the time, most of you don't ride at full throttle, plus you don't accelerate all the time, sometimes you cruse around and do technical riding. The Dobeck units do not have the capability to address fuel delivery for other throttle positions, besides full throttle. It cannot sense throttle position, so it supplies fuel as per the full throttle, acceleration settings only. In most cases this is an serious overkill and causes very rich conditions, messing up your power delivery below full throttle.
The PCIII can sense the throttle position, and delivers fuel very differently depending on throttle position and RPM range. For example, when you cruse around, the fuel delivery is usually around the 14 to 15:1 ratio, but when you accelerate, it goes down to 13:1. You have a cruse mixture for using less fuel and cleaner burn in the combustion chamber. You have a different mixture for acceleration, where you don't care about fuel usage and carbon build-up in the engine.
Also note that running to rich also has it's own set of problems. To rich not only causes heavy carbon build-up, it also causes the fuel to settle on the sleeve, which dilutes the oil which lubricates the rings. If you don’t; lubricate the rings and the sides of the piston correctly, don’t expect it to last. This excess fuel also works its way past the rings and dilutes the oil in your crank case. So, it not only messes up the piston and rings, but all the other parts that need oil to lubricate it. With the Dobeck, I guarantee you that the combustion chamber and exhaust ports will carbon up 10 times faster than with a PCIII, and cause you to open that motor sooner than required and spend money on keeping it running. That little bit you save from buying a Dobeck, compared to a PCIII, will cost you big time in the future.
The Dobeck units work, don't get me wrong, but they are like a patch on a small peace of the problem. So, if you are a guy that uses the bike on the track and you just use acceleration, yes, the Dobeck units are fine, but if you find yourself using the bike for anything else, then the PCIII is the right option.
Next time you have a Dobeck on the Dyno, test the fuel delivery under load at throttle positions other than full throttle and see what it does.
You will see the other side, no one tells you about.
Guys, I am not here to slap down the Dobeck and Noss Boss units, but they don’t address the total fuel delivery problems on the 700R.
