61 - 68 of 68 Posts
· Registered
If I went with 3 can I run stock springs or do I need HD springs
From memory you need springs as well.
I think someone here clarified that recently too.
But, personally, I think it's worth it, as I'de rather have mid to high rpm power, vs power fall off up top.
A spring compressor is cheap too.
Build this thing once, and enjoy it for a long time, even if it takes you a little longer to finish it.
· Registered
A lot of guys complain about losing tons of low end with a stage 3 cam. To combat this, they'll recommend a minimum 11:1 piston. But that can create another problem...the stock connecting rod is a common failure point when you increase compression.. Not good! Given the age of the 660s, you're taking a big risk if you don't replace the con rod.
I know you've put a lot of time and effort into this thing, but playing a bit of devil's advocate, I'd at least consider getting this thing running and sell it, then buy or finance a nice fuel injected 700. You've got to do a lot of modding to a 660 to get it even close to par with a 700. Just something to think about. I loved my 660, but selling and getting a 700 was absolutely worth it.
· Registered
2001 Raptor 660r
Discussion Starter · #63 ·
Are connecting rods expensive. I like the hunt just as much as the kill! I like the nostalgia of the 01 to much. Plus, this is giving me a huge learning opportunity.
· Registered
You'll need a crank and rod assembly, which is around $400-$600(I havn't priced them in a long time).
Otherwise you would need a custom fixture to make sure the crank halves pressed back together in 100% the correct position.
61 - 68 of 68 Posts
