1 - 2 of 2 Posts
I just finished installing the reverse lever control and key relocate with the billet ignition plug, Just have one question.
The billet part is threaded but i didn't see a nut that would go on the threads. Is this kit suppose to have one or are the thread for locking it into the plastic and that's all?
A nut will not fit on the bottom with the shape of the plastic. I made them to screw directly into the plastic fender. I used the Ing. Switch as a wrench from the top but with a little effort you should be able to screw it in by hand. If it seems a touch loose or for extra security you can add a little clear silicone to the threads and that will act as glue for lack of a better term. If you have trouble shoot me a PM and I will give you a call.
Paul
1 - 2 of 2 Posts
