1 - 12 of 12 Posts
2009 Raptor 700 SE
I was draining my coolant, but when I removed the bolt from the water pump nothing came out. The radiator cap was not on. Has this ever happened to anyone? Ended up draining from the radiator hose. After I refilled it I think the water pump was working, but not 100%. While running the radiator hose got hot fast. I ran it with the radiator cap off. The fluid splashed a little, but not sure if it was vibration from giving it small revs. Any input? Hoping I dont have to take water pump apart.
Couple of questions here. 1: are you sure you removed the correct bolt? The lower left one with the copper washer...
2: was your radiator cap off? If not, it creates a vacuum and wont allow the coolant to flow
1 - 12 of 12 Posts
