On my DRD reverse lever the cable keeps comming out of the hole where it goes into the lever part.,I have it adjusted right.But it keeps poping out.Is there a fix for this?
does the cable have the rubber gromet on the end to hold it in? Mine is just a press fit.
Try rubber cement
yeah its rubber
Yes I had the same problem. Re-rout the cable so there is no binding when you turn the bars BOTH WAYS. Also try putting some tape or a clamp up high on the frame to hold the cable in place. My cable kept falling down in front of the oil tank causing the cable to bind up. Good luck.
A-10 Crew Chief
cable on my DRD reverse lever broke, is there a cheap replacement cable or am i going to have to buy a whole new lever?
I had to buy a whole new setup when mine broke last year
