it started when i had a banshee i orderd a dura blue axle and it wasent the right one like the hubs dident fit but i kept it and i still have it now that i have a raptor... is there anyway you can tell what axle u have theres nothing on it that i can see, or when i bought it was i suposed to buy hubs with it? need help thanks
There are only 3 types of durablue axle, the heavy duty and the eliminator use standard OEM hubs, the X-33 is the only one that doesn't, it requires special pin-drive hubs. These are a couple hundred dollars from durablue.
are hubs from all brands of sport atv have the same splines ?
Most of the yamahas are interchangeable, but you can't mix and match brands. for instance, a stock honda hub will not fit on a yamaha axle and a yamaha hub won't fit on a honda.
If that axle won't accept your yamaha raptor 660's hubs and it isn't a pin drive x33 then it's not a banshee (or probably any other yamaha) axle.
