I have a 2007 SE I picked up used and noticed it has a Dynatek mini coil instead of the stock coil. This is not the full Dynatek programmable ignition.
It has ProFlow intake, no lid, complete stock exhaust. My question is can i run the PC V with that coil or will it cause issues ? Thanks
I had a PC5 and Dynatek 3 ohm (never measured it) coil on my 727 stroker, made 70+ HP on the dyno. Even thought the instructions say not to use them together I did. I talked to Daniel at Cuervo Racing and he said it doesn't matter using them together.
Did it help?? IDK, as I did the build all at one time and never changed it.
727 Duner
PC5
5mm stroker
10.7:1 CP piston (I machined the dome for 11.2:1 corrected)
DMC Force 4
FCI, no box
HDD 5050 with Cuervo porting
+1 intake and exhaust valves
+2 throttle body
3 ohm coil
What build are you going with?
Discussion Starter #5
Nothing planned yet, I will definitely build when its needed. I would more than likely go with similar build to yours, maybe less agressive.
Mine was great in the sand, but a handful in the tight trails.
