1 - 10 of 10 Posts
Hey guys its getting close to christmas time and I'm wondering what to do...
I'm in the process of putting a plus 5 crank in:wow:, i already have dmc duals,pclll, stage 2 cam, je 11:1 piston, intake.
I'm thinking of either sending out my head for a p&p by bo or someone or get a dynatek, what would benrfit me the most? ???
Its a trail quad and stock swinger.
Thanks all.
THE SAND DUNES HAVE RULES ----- "Follow Them"-
While its apart, P&P. You can add dynatek later.
The power is hidden in the head of these beast.
I don't know if money is a issue but with a stroker, might want to do some bigger valves too while you have torn down. Like johnjr said, dynatek is a bolt on and can be done later.
With porting and a +5 stroke, your gonna leave alot of power on the table with that HCII cam. If you dont install a bigger cam, at least install HD valve springs and clearance the cam journal and exhaust rocker while the heads off just in case you change your mind in the future.
1 - 10 of 10 Posts
