You can use the stock knobbies, but your not going to get an accurate test. Different knobbies produce different numbers....and all knobbies produce significantly less numbers. BUT, if your just dyno tuning then you could. If your not concerned with numbers and are just trying to tune the bike, the stockers should work fine...as they will give consistant "off numbers".....haha :thumbsup:
