DynoJet Power Commander - Installation & Review - "Is your 700r thirsty 4 fuel?"
Here we go with the installation of DynoJets Power Commander (Part # 412-410) for the 2006 Yamaha Raptor 700r.
Tools Needed:
3/8's socket drive with 6" extension
3/8's size 10mm socket
# 2 screwdriver set
Small Sharp Cutting Pliers
Regular Pliers
4mm Allen
Start off of course with working in a safe roomy work environment.
Remove the seat.
For safety purposes, since you will be working on the electrical, disconnect the positive terminal on the battery.
Remove the arrowed items above using your 10mm and screwdriver. Make sure to set them aside somewhere safe, so you do not misplace them or lose them.
You will also have to remove the gas tank cover and front grille. Remove the arrowed items. For the grill removal push up at a -45 degree angle and the grill will come off. For the gas tank cover push forward up and it will slide off. Make sure to set these items somewhere where there is no foot traffic, wouldn't want anyone to step on these items.
Becareful with the lower fairing mount under the seat area, these are tabbed as well, they slide up and backward.
These are what you should set aside from the quad. If you have any more then you took off too much.
I propped the gas tank up with a small box, but if you have someone else available to help you, thats even better, have them hold up the tank.
Route the cables from the PC into the rubber slotted arrowed shown above.
On the lowest farther right hand corner, you will find the TPS connector, disconnect it and tap into the wire. You will use the connector tap connector provided by PC and connect it onto the yellow wire of the TPS plug. Then plugin the PC wire into the tapped connector. I made a slight cut into the factory boot cover so the boot would be able to accomodate the new connector and be protected at the same time as well. Connect the plug back into the TPS.
Your almost done. Now on top, right underneath the gas tank you will find a plugin connector that is on top of the fuel injector. You will unplug that connector and plug in to 2 connectors, the first will bypass and go into the PC and then the other will plugin directly into the fuel injector.
Now that you are done with everything, do not yet put everything back together!!!!
Grab your key and make sure that you did everything correctly. Start you quad, if it starts then you did everything correctly. If it did not, retrace your steps.
As far as placement of the PC, I used the back part of the Air Box for my placement. What you want to do is make sure that both the sites for velcro placement are cleaned for a good bond. I then applied the one side of the velcro onto the PC and then with the other opposite side on the PC, dropped and pressed it into the PC so that way the velcro pieces are fully aligned.
Do not worry about wet weather riding. The PC will fit right inside the airbox. See above pics.
Now your install is done.
Now for the downloading and aplying of the PC software etc, please go to the below sites for more info:
http://powercommander.com/suppsoft.shtml
Download software, click above.
http://powercommander.com/tut_download.shtml
For animated tutorials, click above.
http://powercommander.com/accelpump.shtml
Free accelerator pump upgrade download, click above.
http://powercommander.com/416-411.shtml
Detailed map info, click above.
It is really easy if you have a laptop, just install all of the software needed. Plug in the USB cable to the PC and then plugin the other end to your laptop. Start the software, start the quad, and there you go, the PC and laptop are communicating. For further info, please read the manual as to what and how to do things.
This mod, allowed the bike to not run lean, and your set of the pants dyno will feel the difference right away. This is probably the best mod you can do for your 700r.
If you have any questions, feel free to PM.
Thanks,
:thumbsup:
Mr. C
Tools Needed:
# 2 screwdriver set
Regular Pliers
4mm Allen
Remove the seat.
Thanks,
:thumbsup:
Mr. C
