Airbox lid removal (requires rejeting)
Clear tube mod for carbs (I think this is a sticky)
For more top speed you can cut the inductor wheel back to 1/2 or only 2 teeth ( inside clutch cover and for max speed only)
If you want less top speed and more punch off the line put in a smaller front sprocket.
Full exhaust - not so cheap
+more that would be best if you just read
Hot Cam. Stage 1 works with the factory valve springs. Stage 2&3 require stiffer valve springs.
11:1 high compression piston.
Use a ProDesign K&N ProFlow kit. It allows you to remove the air box lid wich will gain you about 3 hp. You will need #25 pilot jets when you do this.
Port the head.
You can do the piston, and cam for about what you would pay for a new exhaust system.
What do you mean by easy?
- No internals of the engine?
- No major work done by a machine shop?
- Free?
Aside from hacking away at the speed wheel or disabling the parking brake and reverse limiters or making sure the carbs are properly adjusted there is no such thing as a free 660 performance mod that I can think of.
As alluded to in your other thread, removing the baffle and opening the airbox, with the proper jetting, can add a very modest amount of performance - a small fraction of what a good aftermarket pipe/exhaust with the same airbox mods and proper jetting will do for you.
Drill holes in the air box lid and box, but you will need to rejet and buy aftermarket needles, and they arent free............
