1 - 11 of 11 Posts
Breathe my dust !
I saw that some people are still having trouble relocating their P-brake.
So here's Imo the easiest way to relocate it to good place on the frame.
It should work for all the Raptors, as long as they have a bolt on P-brake lever and a tubular Frame. This is the example for the 700.
All you need is a spare clutch perch.
STEP 1:
Cut off the lever piece of the stock clutch perch, keeping only the P-brake mounting holes.
STEP 2:
Re-route the P-brake cable where it'll be mounted.
STEP 3:
Bolt on the stock clutch perch on the frame. USE LOCKTITE because the bolts are very likely to come loose.
STEP 4: Just mount the P-brake lever on the perch ;)
I used another metal piece for a better lever position.
You no more have to get rid of the P-brake when you rise your bars or extend your swinger ;)
I relocated mine to the trash can.....IMO you don't need it anyway.:)
Breathe my dust !
Well I allready rode without it and I hate it. I ride mine one road too so I park it in many places, plus most of the places I park mine aren't flat.
I just hate putting a gear on.
Lol, I did too, now if I park on a hill I just tie the front brake lever to my handlebars with a piece of wire, imo it works better than the pb
Breathe my dust !
The utility of the P-brake is not the point, some people like me just want to keep it so for thoses ones I figured that this is the easiest and most practical way.
Awesome write up man!
Thanks, hope it helps someone lol :D
Understood from both point of views on the pb. Ive never really cared for the pb either but it is nice to keep if its your thing. I dont even use my pb in my vehicles lol.
Here's mine if you can see it.
Breathe my dust !
That's a nice place too, didn't want to put mine here because I was afraid of hitting hit with my boot if I miss a trick.
1 - 11 of 11 Posts
