Hey guys and girls I have a quick question.
Would it hurt to run two of the fan relays. 1 for the fan and one for your lights?
The reason I ask is my lights relay went out on me and I orderd a new one and it was the fan relay. I plugged it in and only my high beams work. I can handle that. But would it hurt anything to do that?
for the most part, a relay is a relay is a relay....when you're working in auto, as long as it has the right magic inside then you'll be fine. For the most part, relays are the same within one application, check the part numbers
