1 - 2 of 2 Posts
My bike will turn over has good compression but no spark it's missing a silenoid so I have to install a new one any other things that might cuase that issue and does anyone have a videoxof how to install a silinoid beacuase there wasn't one on there when I bought it
You need to make sure that key switch is on and run/stop switch is in run position - this supplies 12V to the CDI which is what generates the spark pulses for the spark coil.
RE the solenoid, Use one made for this quad. There's a three pin connector and a fuse that plug into the top and there's two large lugs - one goes to battery+ and the other to the starter. If NOTHING works (lights, etc), reverse the two large cables on the lugs. There are two slots for the fuse, one is active the other is just for spare storage - you can tell which is active because it has metal contacts inside.
Good luck and check back with more questions or success stories!
1 - 2 of 2 Posts
