1 - 20 of 106 Posts
Hey guys,
Just rebuilt my L&A one-way starter bearing, and finally got the machine back together.
Went to start the quad, and it would crank slow (fully charged battery), as if the battery was dead . At the same time, I would get spark (like a loose connection) from the positive terminal. Positive wire would get hot very quickly.
To me, it sounds like something is binding up. Before the starter bearing went out, I had a positive terminal on a brand new battery, melt. All the connections were strong and tight.
Going to take some time and back track the issue.
I do have another wire harness, spare ignitions, CDI, ect.
Not sure what to do. Tried switching the start switch. Blowing the positive fuses now.
Any suggestions would be great.
I've got all winter to fix it.
Loosen the starter and wiggle it around some - sometimes it gets 'cocked' in the side case bore due to the very tight o-ring, causing it to bind with the intermediate gear.
Does the bike start finally? THere's always the chance that the engine is binding up or the starter's bearings are bad. Pull the spark plug and see if things crank over normally. If not, then pull the starter intermediate gear and check again.
Blowing fuses should be unrelated to the slow cranking. The only fuse in the system (the other one on the solenoid is just a spare) is outside of the starter circuit. Since the fuse started blowing only when you swapped solenoids, I'd suspect the new solenoid first... but it's much more likely that you have a wire shorting somewhere. Under what conditions does the fuse blow?
A spark from the battery terminal implies a bad connection - one or the other surfaces dirty or corroded. Disconnect and clean both the battery's and the lug's mating surfaces with a wire brush then reconnect and tighten with a wrench - you can't get them tight enough with a screwdriver.
Also wiggle the wire near the lug and make sure that it is intact. Corrosion can get inside the lug or the insulation near the lug and eat away at the copper, leaving a poor connection that will get very hot under starting current.
I'm betting that the slow crank / hot terminal is related to a bad or corroded connection at the battery.
Willy- you hve what sounds like a "shunt" condition on your positive turminal side(weak connection or feed) Are you using the stock size wire to batery? if not-replace. besides cleaning the terminal REAL GOOD, check the connection at the starter. Clean again. I sugest using a wire brush on all conections. If still poblems, check solinoid/starter. lol
I don't see how connection issues at the starter are going to cause sparks/melting at the battery terminal - this is caused solely by high current passing through a higher than normal resistance ONLY at the point where it is heating. Poor cable connection at the starter could cause slow cranking, but due to the other symptoms, I don't think it's connection at starter related - it is most likely loose or corroded connection at the battery (as we both described).
This also doesn't meet the definition (as I understand it) of a 'shunt'. Exactly what are you describing in the use of this term? A shunt (relative to battery systems) is typically a connection inserted in series with a battery feed with a low, known resistance so, by measuring the voltage drop across the shunt, the current passing through it can be calculated.
You are correct in all your assertions. I used the term "shunt" in quotes to describe a genaric not absolute condition. That is that there is a restriction in current flow or high resistance due to a bad or lose connection. I should be a little more specific in my laguage. Sorry. I forget you are a EE. I thought ALL conections should be cleaned as a matter of completness, not cause. Ill try to clean up my language. Thanks for straitening me out. Hope all this helps willykiller.
LOL, np, Thumper. You've got the understanding of the basic issue, I beleive. But now you have me lost... what's a 2 legged deer?
Let me see if I can help. Here is a hint. Thay walk round on the beach with a two piece bathing suit on (depends on the beach) Hence the term "Two leg deer." Bouth two and the four leged version are hunted by man. Sorry to get off track. I hope we helped Pardee. He hasent chimed in with results. What is the outcome?
I get the point, sorry for my denseness. I'd rather have a two legged DEAR for a little cheer.
He's either found the problem and doesn't need us anymore, or hasn't got around to checking our suggestions yet... we'll see.
Discussion Starter #12
Starting problems... electrical
Hey guys,
Just got my computer back.
I was out in the garage tonite looking things over.
Before I rebuilt / replaced the starter clutch, the positive wire was getting hot just by cranking.
The quad is partially cranking.
Instead of crank, crank, crank, I get crank, pause, crank, pause, crank.
Does that make any sense?
It seems as if it's drawing more power, but not continuously cranking.
Hey guys,
Check for bad connections in the start circuit of a bad battery.........
And as far as the two and four legged deers, I prefer the two legged deers, they are much more pleasing to the eye..........
Depends on the deer....
Pardee-still sounds like you have a bad connection at starter circut. Recheck all connections and clean. You do have 12.5 volts at battery, correct?
Still sounds like a bad connection at the battery.
If that doesn't fix it, put a voltmeter on the battery and crank it over. Less then 10 volts or so and you have a bad battery. It is possible to read 12.5 volts static and the battery won't carry the starting load.
Discussion Starter #16
Electrical problems
I'll grab a multimeter from my father-in-;aw today.
I do appreciate the help guys.
Discussion Starter #17
The battery sits at 12.5V. when sitting untouched.
Checked the battery during crank, sitting at 6.5V.
Battery's either bad or requires a very good charge... I'm betting on bad.
Discussion Starter #20
Would you suggest that the melting terminal was due to a defective battery?
The battery was purchased November of last year, and has had less than 30 hours of riding on it.
I called the manufacturer when it happened, they said there was nothing they could do. I'll never but a cheap Everstart (Neverstart) again.
1 - 20 of 106 Posts
