RAPTOR 660 - RAPTOR 700
E36 Triple Rate No reservoir No adjustment $485.00
PB36B Triple Rate Piggy Back No adjustment $750.00
RR36B Triple Rate Remote No adjustment $750.00
PB36C Triple Rate Piggy Back Compression $895.00
RR36C Triple Rate Remote Compression $895.00
PB36CR Triple Rate Piggy Back Compression & Rebound $1 095.00
RR36CR Triple Rate Remote Compression & Rebound $1 095.00
Elite PB36C Triple Rate Piggy Back Compression (HS/LS)* $1 255.00
Elite RR36C Triple Rate Remote Compression (HS/LS)* $1 255.00
Elite PB36CR Triple Rate Piggy Back Compression (HS/LS) & Rebound* $1 465.00
Elite RR36CR Triple Rate Remote Compression (HS/LS) & Rebound* $1 465.00
For long-travel a-arms only:
E36 LT Quadruple Rate No reservoir No adjustment $615.00
PB36B LT Quadruple Rate Piggy Back No adjustment $875.00
RR36B LT Quadruple Rate Remote No adjustment $875.00
PB36C LT Quadruple Rate Piggy Back Compression $1 095.00
RR36C LT Quadruple Rate Remote Compression $1 095.00
PB36CR LT Quadruple Rate Piggy Back Compression & Rebound $1 395.00
RR36CR LT Quadruple Rate Remote Compression & Rebound $1 395.00
Elite PB36C LT Quadruple Rate Piggy Back Compression (HS/LS)* $1 360.00
Elite RR36C LT Quadruple Rate Remote Compression (HS/LS)* $1 360.00
Elite PB36CR LT Quadruple Rate Piggy Back Compression (HS/LS) & Rebound* $1 675.00
Elite RR36CR LT Quadruple Rate Remote Compression (HS/LS) & Rebound* $1 675.00
REAR SUSPENSION * Elite : High/Low speed compression adjustable
RR46CR/SSD Dual Rate Remote Compression & Rebound $875.00
Elite RR46CR/SSD Dual Rate Remote Compression (HS/LS) & Rebound* $1 045.00
Linkage YFZ450 Must be used exclusively with Elka shocks, provides 13 inches of wheel travel $265.00
Linkage Raptor 660 Must be used exclusively with Elka shocks, provides 11.5 inches of wheel travel $265.00
I can get any of these setup for your weight.
Let me know which one you want, and I will send you a discounted price.
Take care
Kenneth
Take care
Kenneth
