1 - 17 of 17 Posts
engin is pining
hello there first time on that forum you guy do a nice job with all your answer ,
here is my question my engine is pinking wen i am in low torque what will be the the best way to fix that problem,
i run on pump gas 94 octane and i add octane booster
my engine was built by a professional shop whit dyno a pull 67.14 hp @ 7500 rpm and 52 tq
here is my set up
raptor 700 r se 2008
dual dmc force 4
11.5 piston
weeb cam custom grind
kibel white spring
+2mm valve
monster flow with k&n filter
pcv
complete head and valve port
thanks jul
dl do you mean the spark plug ??
and the air fuel ratio was 12 ..1 a think
its possible the low rpm mid throttle range is too lean... email me the map and ill take a look
Yes the PLUG
CR8e is stock go to a 9
i like to run the CR9EKPA plug... its spendy but works well
ok thanks il get it tomorow
them are very impressive numbers for such a mild build'' that would be a very fun dunner bike'' :cool:
Yo mon Julien, bienvenue sur le forum :) (Jul is an old RL friend of mine, almost family!)
Mine has been pinging ever since I went with my first HC piston... Never bothered with it and still running strong. Danny told me it didn't ping when he ran it on the dyno though but whenever I shortshift 4th or 5th and lug it makes a pretty loud ping... I just shift higher to compensate :p Always ran 91 in it.
yes stock bore and stroke
When "pinking" just rub till moist then ride it hard! Install a longer stroke if needed.
What kind of octane booster?
There's pump 94 in some stations in our area so no booster in play, just higher-than-normal-octane pump gas.
i use klotz blue can like 1 oz per gallon ! in 94 octane pump gas
Cola Crew
How about gearing? Do you lug the motor down low and it pings or is it at WOT.. Im thinking that you are lugging it down to low in the RPM's..
Cola Crew
Not alcohol compatible.. So how much alcohol is in the 94 that you are using.. most fuel has 15/20% now and I use 93 to lean out my shell 110 ie 2gls of 110 and 3gls of 93 with 15% alcohol.. This is what works for me..
Discussion Starter · #16 ·
i don't no how mutch alcohol there is !!
i do only traill riding and forestery road we make around 120 up to 200 miles on a week end so it is imposible for me to bring enough gas with me i have to run on pump gas !!!!!!!!!!
and yes it is wen it's in low rpm and i gun it the engin ping !
Quit lugging it and go plug DL told you about, they can be found at the kawi dealers. Just raise your shift points a bit and you'll be good i almost bt the farm on it.
1 - 17 of 17 Posts
