OK, I'm not an ATV guy at all, I actually had to go read the instruction book to get the thing in reverse to get it out of the truck (the guys working next door thought it was really funny).
I'm building/restoring/modifying a 1958 Berkeley SE 492 racecar, originally equipped with a 2 cycle, 3 cyllinder 492cc engine, with triple carbs, that engine is long gone though. The car in race setup only weighs about 630lbs and is considered a mini car. It is however very quick and nimble with all wheel independent suspension, coil overs an aluminum monococ type frame and fiberglass body.
The car will have a completely new front clip to house the motor, tranny and differential from a brand new 2006 Raptor 700R. Shifting will be done using buttons on the steering wheel and solenoids.
For the last few days I've been browsing the forum and am getting some great information.
So I know to get the powercommander and a custom map made, also I'm getting the quick shifer attachement to allow me to shift (buttons) without the clutch.
Now for the question: I get to build a completely custom exhaust and airbox system, without the limitations that you would normally have on an ATV like the frame, space to put your legs or seat, mounting points.
What would you do if you had to design/build a custom exhaust manifold?
Should I use a crosspipe for dual exhausts?
What would you do for a custom air intake? (dust and mud won't be a big problem)
The exhausts I'm planning on using can be seen here, they will be side exhausts under the doors : http://www.raskcycle.com/parts/pipes/42-2653.jpg probably one on either side.
Any help will be appreciated.. I posted some pictures in another thread: http://www.raptorforum.com/index.php?topic=11677.0
Rob
Rob
