go ahead and do the 11:1 and the stage 2. Both are solid choices for most Raptor applications and neither can be beat in the bang-for-the-buck department. See how you like that, if its not enough power, you can always have the head flowed and get some duals and FCRs when you do. My 673 makes 65HP and 49TQ with the cam and piston you are going to use. Now I get that much because of the porting and use of the Barkers and 39FCRs but even without those, you will have a solid foundation to build from.
BTW, I'd recommend you just go with the 101 bore piston, that way your sleeve still has room to be bored once more if ever necessary and you get a good, fresh and true bore to work with by boreing it 40 over, just make sure you use a reputable machine shop and they set the piston to wall clearance to .003 on the Wiseco.
