I know there was a guy on her selling his epic case saver because he said that it did not fit with a 15 front sprocket. Well I just put my 15 back on with the epic case saver and it fit. Just need to grind a little from the bottom on the inside and theres no problem you also need to use the factory little metal case saver with this epic case saver, but even with the stock 14 you need to use it. Well just wanted to let people know that it would fit so go on and bling them 700s out.
