i have an 03 raptor 660 i have an exhaust header stud broke of so its only clamped down tite on one side so i was wondering how much power i might be losing or if its harmfull to run the wheeler like this? thanx alot..
Cranking down 1 bolt to do the job of two will more than likley cause the remaining bolt to break.
You best bet is to fix it.
I did this. To fix it i was able to weld a nut onto the broke stud. I speed cooled it down with water. Then i took my impact gun which was adjusted down to 40 PSI and let it go. It worked it out and i was able to order new ones and its all fixed. My motor was out of the frame so it was easier to do.
