1 - 14 of 14 Posts
06 700 with Flex handle bars and my steering stem is bent. I am thinking of going with a +2 steering stem. It is so close to the plastic. I have kinda adapted... Should I go with that or a +1? Also, I was thinking Houser or Alba steering steams....Any suggestions/ support reasons?
Thanks GUYS
I have a +1 houser with anti-vibe stem with flex bars and i like it. Im only 5'8.5" so it works for me. I think there is enough cable and wire for a +2 but not positive.
Reactions: DEZPERADO
+2 is stretching it for factory cables. If so, Motion Pro clutch and throttle cables are 2in longer then factory.
WELCOME TO THE FORUM.
Thanks GUYS
I'd lean towards the Houser stem. How tall are you? I'm 5'11 and prefer the plus two inch stem for aggressive riding while standing.
270-774-1982
Thanks GUYS
Sent from my SM-G900R6 using Tapatalk
Flex bars and rox anti vibe riser. Love it.
Thank you guys for the response I need to do something. I was also leaning towards the Houser.
KB Motorsports, YA I am 5'10" so I am going to figure +2 with probably the cables that DEZPERADO suggested.
KB Motorsports is a reputable forum vendor. Don't worry about purchasing from them.
They have varying degrees of flex to help with rider fatigue. My wrists, upper back and shoulders dont hurt as bad after riding all day or doing some moto. Some people hate them, some like/love them. I love mine. It was a very hard decision for me to make between the flexx or precision bar clamps.
Reactions: Joshua A Treace
I've been looking at the Rox 2" anti vibe risers. Any negative feedback on them? The one I found is two separate pieces, any excessive flexing or moving in the bars?
Flex can be adjusted by tightening or loosening the nuts. They will rub the tank. So got a couple of bar clamps and put on the bottom of the other ones and longer bolts to lift it up just enough
I personally went with the precision stabilizer. I'm not young anymore so having either the flexx bars or a stabilizer definitely helps at the end of the day. I was looking at the flexx bars, but they wouldn't work with the dashboard that I have.
2020 Yamaha 700R
Is using both the precision stabilizer with the flex bars overkill ?
1 - 14 of 14 Posts
