Hey guys i own a raptor 350 i have installed a pipe and a k&n filter paddles
but i still want my raptor to go faster, is there anything else you guys recommend that i can install to make it go faster?
i have been thinking about the rev limiter.
Big bore kit might add some Hp's. you may want to adjust your gearing (sprocket size) might give you more top end speed but you will loose low end acceleration.
Its a 350 with a 2 valve cylinder head. There is only so much you can do with that as far as power. The engine is known for reliability, but not for lots of power. If you want faster then you will probably have to upgrade to a 660 or something.
