Hello! Could anyone tell me if 06 raptor fits any older fenders for example from 04!05 660cc. Or maybe from 13?
Thank you!
All 700 rear fenders are the same, 2006-2021.
2006-2012 front fenders and headlight mounts are the same.
2013-2021 front fenders are all the same, but require the 06-12 headlight mounts to fit the 06-12 models.
VIP
The 2013-21 front fender swap can only be done on the 06-08 models, as the 09-12 have the digital dash and the hood will not fit.
To swap the 13-21 fronts to an 06-08 you actually need the fender/headlight brackets for the 13-21, as they moved the fenders forward 2".
To swap your 06 to the 13 and newer fenders you will need...
Fender/Headlight brackets
2 spring clips for the top of the hood to fender
Plastic radiator stone guard(Available in red, black and pastel blue)
Hood
Tank cover
Smaller headlight trim rings from 13-21 model
Yamaha tuning fork emblem for front of hood
There are some foam isolator pads and rubber pads you should also get. You will see where they are located if you remove your stock fenders and tank cover.
What colors are you looking for?
