I'm reading the owners manual and it doesn't make sense.... follow me here...
It says.. "
10. Install both drain bolts
11. Install crankcase engine oil filler cap (why the hell have an crankcase engine oil filler cap if you don't use it to fill the crank with oil)
12 Pour only 1.16 US qt of oil through the engine oil tank filler hole, insert the dipstick, and tighten
13. start the engine and rev it several times.
If I understand correctly... the engine is starting with no oil in the crank... hence why the crankcase oil filler cap.
grrr... maybe I'm just an idiot... help please.
It says.. "
