1 - 20 of 20 Posts
So I was at SuperStitions in CA, and I decided I was going to fly back to the camp site. So i throttled it and saw one of those berms that are made by people doing donuts for hours and decided to jump it. When I landed I saw the other side of the berm. The steep side. So I hit that pretty fast and went ass over tea kettle. I was bruised up pretty good and had some nice "road rash". My bike broke off the left headlight, left clutch lever and left parking brake lever with housing. The handle bars folded all the way back to the gas tank. Radiator is tweaked but no leaks. And I messed up some plastics.
So I was checking out my bike some days later to access the damage. I checked out the handle bars and saw that all I really needed to do was loosen the bolts and rotate the handlebars right back into place. Bonus.
I bent the plastics and metal holders back into place and JB Welded the headlight bracket that broke. Order new levers
So now it appears that my bike is ready to go out again. So I sat on my bike and turned the handlebars all the way to the right and left. I noticed that the steering stem now contacts just a bit of the gas tank when at full turn on both sides.
Is this the steering stem that is bent? It only slightly touches the gas tank at full turn. Do you think this will be a major issue?
This pic was right after I went down.
You've either bent the stem or the top hoop that the upper stem mount is bolted to, both are real common in a wreck like you had.
X2 and they usually bend together I would plan on fixing both. I just had the same problem with mine and i bent both. had to get new stem and bend the hoop back.
Yeah or send it to me and I'll rebuild it for ya out of chromoly ;)
Hope your ok. I guess some new shtuff is coming in the mail thats always fun.
Will I still be able to ride it or is this something that you should fix prior to?
Discussion Starter · #14 ·
You bent it good, Is it hard to get the gas cap off?
Its only touching the gas cap in that pic because I have the handle bars turned all the way to the left. I was just showing that when I have it fully turned it touches the cap. It only touches a bit. does not block anything.
You can ride it. It will just be annoying when you turn sharp your handlebars will keep hitting your tank. Rode my banshee for years with bent hoop and stem but it didn't bump the tank just made plastic bulge out a little
Discussion Starter · #17 ·
Sweet. I just hope the next time I take it out, (Pismo this weekend), that there are not other problems that I did not find earlier.
Whats that stuck between the front rails on the crash pic?
1 - 20 of 20 Posts
