1 - 2 of 2 Posts
Ok here my problem, i was having starter problems like 2 months ago, i opened up my side casing, n the 6 bolts that hold the starter clutch to the flywheel were all broken. i replaced them all with 8 gauge screws. now they went again. i have a big bore kit on my bike, could it be because of the compression? has any1 had this problem?, found a diff solution. please help.
yeah, this has happened me loads, i went for harder screws- 12.9s i think they were. been fine ever since, only thing is if they do come out, they will mash the tranny. i found kick back far worse with high comp, i stall my bike instead of switch off, it holds the kick back a bit, hope this helps
1 - 2 of 2 Posts
