61 - 80 of 100 Posts
Discussion Starter #61
Discussion Starter #62
This new forum format won't let me edit to update the list, but;;
All spark plugs are sold.
All front brake pads are sold.
Only rear brake pads left are "Factory Spec FS-428" .
Tomorrow marks 2 years since I started my selling spree on the forum, 2/27/18. SO,,, until the end of the month, I'll do a 10% discount, or more based on all items. Although I've sold a lot, BUT, I have a lot of good things left. If you don't see it, just ask.
Discussion Starter #64
Complete list updated and more added. New and used parts for sale. Let me know what you're interested in and I'll get you a package deal with shipping. I can send pictures to a phone or email.
The more you buy, the more you save!!
NEW PARTS;
$200, Raptor 700, CP 105.5 big bore stroker pistons
$13, Raptor 700 Throttle cable in throttle body "brass" connector
$20, Raptor 700 left headlight bracket (old body style)
2013 Raptor 700 SE Decal set. Red, White and Blue
$17 each, Parking brake lever relocator. Used with hand guards for clearance.
$60, 700 Pivot Works A-Arm pivot needle bearing kit, #PWAAK-Y02-000L. Banshee, Blaster, Warrior, YFZ450, Raptor 250/350/660/700
$25, 4, new tie rod ends, 2 left, 2 right. Fit Yamahas including YFZ450, Raptor 660, 700, and Arctic Cat 150, 250, 300, 400. Kawasaki 400, Polaris 90, Suzuki 250,400, and 500.
$17, 700 Stator Wire heat shield
$14, 700 Factory Spec FS-428 Severe Duty rear brake pads. 450 Rhino-660, 700
$14, Raptor 700, 14 tooth front sprocket
USED PARTS;
$15, 700 Like new coil, take off
$25, 700 Starter Motor
$20, 700 Starter gears
MOST electrical bells and whistles, ECU, starters, stators, fuel pump, coils, etc.
$25, Factory injector, Raptor 700, cleaned and tested. Good for up to about 65-75HP.
$75, 550 injector, Raptor 700, good for about 85-90HP or E85,
$200 GREAT Transmission except reverse, and have other internal parts.
700 shift forks and drum
700 Plastic, tank covers and undertails, some new and assorted colors
$95, Seat, excellent condition, no rips or cracks, Raptor 700.
$180, Extended steering stem with Anti-Vibe clamps, 7/8 and/or 1 1/8 bars. 700 +1.5, 660 +2.0, 450 +.5, Banshee +2.5
Rear axle bearings and seals, Raptor 700.
$95, Front calipers, good pads, hoses and master cylinder w/lever, Raptor 700, or upgrade for 660. (Complete front brake system).
$55, Front calipers, lots of brake pads left. Raptor 660, may need rebuild kit.
$20, Front rotors, Raptor 700 and 660
$40, Front winch mount, Raptor 700
Tie rods; stock, and extended, and HD tie rods and HD tie rod ends (HD tie rod ends require spindle drilling). Raptor 660, 700
$35Pr - $45Pr, Rear wheel hubs, 4/115, fits ALL Yamaha sport quads.
$40Pr, Front wheel hubs with rotors, 5/156, YFZ450, Raptor 660, 700, and Banshee
$20Pr, Front rotors, YFZ450, Raptor 660, 700, Banshee
$40, Raptor 700 oil tank and hoses
$45, Raptor 700 Gas tank, nice
$14 each, 4, In-line billet, water coolers, universal
700 motor mounts
Raptor 700 swing arm
700 valve and cam covers.
700 Ignition switches
THOR, Phase, Blue Riding pants, padded, Size 40, but fit my 36-38 waist well.
Bilt Riding boots, size 12, blue & black.
Side cases, stators, one ways, clutch assemblies and individual parts.
Raptor 700 foot pegs
Raptor 700 foot pegs, lowered 1in, forward 1in.
$85, Raptor 700 HD rear shock spring, 250-300lb. Also works with extended swing arm. PM for recommendations.
$85, Raptor 700 HD rear shock spring, 300-375lb. Also works with extended swing arm.
Need more, just ask. I have lots more then what's listed'
THANKS, Larry
Discussion Starter #65
I already arrived in Costa Rica the package, recommended
Enviado desde mi SM-N9600 mediante Tapatalk
THANKS for the recommendation. Good luck with your build.
I need good shift forks for a 700. Maybe that throttle cable. And im very interested in the adjusted footpegs
Discussion Starter #67
PM sent.
Discussion Starter #69
Thanks for the fast shipping and quality parts, broke in new plug today ?
I'm glad you like them. The brake pads will take a little longer to install then the plug.
THANKS.
Discussion Starter #71
Discussion Starter #72 (Edited)
NEW PARTS;
Throttle cable, +2in
$13, Raptor 700 Throttle cable "brass" connector in the throttle body
$old, 700 Stator Wire heat shield
$old spark plugs all sold
USED PARTS;
$60, One stator sold, one left.
$200 GREAT Transmission, no reverse, and have other internal parts.
$40Pr, Front wheel hubs with rotors, 4/156, YFZ450, Raptor 660, 700, and Banshee
700 motor mounts
Raptor 700 foot pegs (Pending)
THANKS, Larry
List updated again after end of month sale. Still lots of great things left!!
Do you have any sand wheels/tires?
Discussion Starter #74
Of course. I have a pair of used, 20x8 (I think) 8 paddle Haulers.
And a new pair of 6x10in front wheels, no tires.
I can send pics tomorrow. Do you want a shipping quote too?
Oh hell Yeah! Thanks brother!
Discussion Starter #76
I'll send pics, but you might not like the tires I have. For your build and dry sand I would suggest 21x12, 8 or 9 paddle Scats. Keep a eye out on your local Craig's list or Offer-Up.
I
More new and used parts for sale. Let me know what you're interested in and I'll get you a package deal with shipping. I can send pictures to a phone or email.
$25, 4, new tie rod ends, 2 left, 2 right. Fit most Yamahas including YFZ450, Raptor 660, 700, and Arctic Cat 150, 250, 300, 400. Kawasaki 400, Polaris 90, Suzuki 250,400, and 500.
$?? pr, Tusk HP TA125R Sintered front brake pads, both sides, Raptor 700
$55 both pr, Raptor 700, Factory Yamaha 3B4-W0046-00 and -10 Sintured front brake pads, L&R both sides
$15, 700 Factory Spec FS-428 Severe Duty rear brake pads. 450 Rhino-660, 700
$29, EBC FA428X carbon Graphite rear brake pads. 450 Rhino-660, 700
Some lightly used parts, you may be interested in, the more you buy, the more you save....
$??, 700 Like new coil, take off
$??, 700 Starter Motor
MOST electrical bells and whistles, ECU, starters, coils, etc.
$200 GREAT Transmission except reverse is chipped, and have other internal parts.
I have more new and used parts you may be interested in. Started with enough parts for a complete 700 except a frame. PM me what you need, want or just have to have.
THANKS, a few more things.
Raptor700SE Decal Set, Red, White and Blue
$14, 14 tooth front sprocket, Raptor 700
[/QUOTE
Do you have any white or black plastics for a Raptor 660.
Discussion Starter #79
