101 - 120 of 136 Posts
Discussion Starter · #101 ·
Complete list updated and more added. New and used parts for sale. Let me know what you're interested in and I'll get you a package deal with shipping. I can send pictures to a phone or email.
The more you buy, the more you save!!
NEW PARTS;
$200, Raptor 700, CP 105.5 big bore stroker pistons
$13, Raptor 700 Throttle cable in throttle body "brass" connector
$20, Raptor 700 left headlight bracket (old body style)
2013 Raptor 700 SE Decal set. Red, White and Blue
$17 each, Parking brake lever relocator. Used with hand guards for clearance.
$17, 700 Stator Wire heat shield
$14, 700 Factory Spec FS-428 Severe Duty rear brake pads. 450 Rhino-660, 700
$14, Raptor 700, 14 tooth front sprocket
USED PARTS;
$15, 700 Like new coil, take off
$25, 700 Starter Motor
$20, 700 Starter gears
MOST electrical bells and whistles, ECU, starters, stators, fuel pump, coils, etc.
$25, Factory injector, Raptor 700, cleaned and tested. Good for up to about 75HP.
$75, 550 injector, Raptor 700, good for about 85-90HP or E85,
$200 GREAT Transmission (no reverse), and have other internal parts.
700 shift drum
700 Plastic, tank covers and undertails, some new and assorted colors
$95, Seat, excellent condition, no rips or cracks, Raptor 700.
$180, Extended steering stem with Anti-Vibe clamps, 7/8 and/or 1 1/8 bars. 700 +1.5, 660 +2.0, 450 +.5, Banshee +2.5
Rear axle bearings and seals, Raptor 700.
$95, Front calipers, good pads, hoses and master cylinder w/lever, Raptor 700, or upgrade for 660. (Complete front brake system).
$55, Front calipers, lots of brake pads left. Raptor 660, may need rebuild kit.
$20, Front rotors, Raptor 700 and 660
$40, Front winch mount, Raptor 700
Tie rods; stock, and extended, and HD tie rods and HD tie rod ends (HD tie rod ends require spindle drilling). Raptor 660, 700
$35Pr - $45Pr, Rear wheel hubs, 4/115, fits ALL Yamaha sport quads.
$40Pr, Front wheel hubs with rotors, 5/156, YFZ450, Raptor 660, 700, and Banshee
$20Pr, Front rotors, YFZ450, Raptor 660, 700, Banshee
$40, Raptor 700 oil tank and hoses
$45, Raptor 700 Gas tank, nice
$14 each, 4, In-line billet, water coolers, universal
700 motor mounts
Raptor 700 swing arm
700 valve and cam covers.
700 Ignition switches
THOR, Phase, Blue Riding pants, padded, Size 40, but fit my 36-38 waist well.
Bilt Riding boots, size 12, blue & black.
Side cases, stators, one ways, clutch assemblies and individual parts.
Raptor 700 foot pegs
$85, Raptor 700 HD rear shock spring, 250-300lb. Also works with extended swing arm. PM for recommendations.
$85, Raptor 700 HD rear shock spring, 300-375lb. Also works with extended swing arm.
Need more, just ask. I have lots more then what's listed'
THANKS, Larry
List is updated.
SPECIAL, FREE SHIPPING on all parts or package deals over $100, till the end of April..
Discussion Starter · #103 ·
Hey Dez
I have a 2012 700R. Looking for urmosi, exhaust, PC 5, skid plates, nerf bars, potentially black wheels, intake system.
Can you send pics of the decal set?
PM sent.
I am looking for a rear brake cylinder for a 2008 Raptor. ~ If you happen to have one laying around
Discussion Starter · #105 ·
Master cylinder, Yes I have one.
Brake caliper, no, unless you can adapt.
Discussion Starter · #107 ·
Any man, with this many parts, for so many machines, in his garage, truly has a sickness...much respect sir, lol
I've been in this since the '60s with all brands and models .
Reactions: Sixpack577
More new and used parts for sale. Let me know what you're interested in and I'll get you a package deal with shipping. I can send pictures to a phone or email.
$60, 700 Pivot Works A-Arm pivot needle bearing kit, #PWAAK-Y02-000L. Banshee, Blaster, Warrior, YFZ450, Raptor 250/350/660/700
$25, 4, new tie rod ends, 2 left, 2 right. Fit most Yamahas including YFZ450, Raptor 660, 700, and Arctic Cat 150, 250, 300, 400. Kawasaki 400, Polaris 90, Suzuki 250,400, and 500.
$?? pr, Tusk HP TA125R Sintered front brake pads, both sides, Raptor 700
$55 both pr, Raptor 700, Factory Yamaha 3B4-W0046-00 and -10 Sintured front brake pads, L&R both sides
$15, 700 Factory Spec FS-428 Severe Duty rear brake pads. 450 Rhino-660, 700
$29, EBC FA428X carbon Graphite rear brake pads. 450 Rhino-660, 700
Some lightly used parts, you may be interested in, the more you buy, the more you save....
$??, 700 Like new coil, take off
$??, 700 Starter Motor
MOST electrical bells and whistles, ECU, starters, coils, etc.
$25, Factory injector, Raptor 700, cleaned and tested. Good for up to about 65-75HP.
$200 GREAT Transmission except reverse is chipped, and have other internal parts.
I have more new and used parts you may be interested in. Started with enough parts for a complete 700 except a frame. PM me what you need, want or just have to have.
THANKS, a few more things.
Raptor700SE Decal Set, Red, White and Blue
$14, 14 tooth front sprocket, Raptor 700
Interested in the set of tie rod ends, seat, rear bearings and seals, and a brake light assembly if you have one. Thank you.
Discussion Starter · #109 ·
Tie rods ends, bearings are sold. I may have rear seals and brake/tail lite left. I'll look.
Discussion Starter · #111 ·
used stator assembly, how much..?
Yes, I have a couple stators. Do you need a regulator too.
I'm out of town and don't have access to my prices. If I don't get back to you by the end of the week, PM me.
Hey Dez, do you still have a seat for an 06 700 ?
Discussion Starter · #113 ·
Click on your profile pic and go to the tab that says conversations. That’s your pm - “personal messages”
Discussion Starter · #116 ·
Ok i guess its been a while since ive been on here and im dumb lol, but how in the heck do i check my pm
You should have a red dot by your picture. Click on it, then look for the dot by conversation.
You should also have a alert dot for my replying to your post.
Discussion Starter · #117 ·
$60, 700 Pivot Works A-Arm pivot needle bearing kit, #PWAAK-Y02-000L. Banshee, Blaster, Warrior, YFZ450, Raptor 250/350/660/700 SOLD
$25, 4, new tie rod ends, 2 left, 2 right. Fit most Yamahas including YFZ450, Raptor 660, 700, and Arctic Cat 150, 250, 300, 400. Kawasaki 400, Polaris 90, Suzuki 250,400, and 500. SOLLD
$?? pr, Tusk HP TA125R Sintered front brake pads, both sides, Raptor 700 SOLD
$55 both pr, Raptor 700, Factory Yamaha 3B4-W0046-00 and -10 Sintured front brake pads, L&R both sides SOLD
$15, 700 Factory Spec FS-428 Severe Duty rear brake pads. 450 Rhino-660, 700 SOLD
$29, EBC FA428X carbon Graphite rear brake pads. 450 Rhino-660, 700 SOLD
$95, Seat, excellent condition, no rips or cracks, Raptor 700. SOLD
Rear axle bearings and seals, Raptor 700. SOLD
List is updated.
How about 10% discount for 4th of July
Discussion Starter · #120 ·
do you happen to have a clutch cover for a 660??
Sorry no, only for a 700.
I don't have a lot of 660 parts left, anything else you might need.
