ok so here soon i am going to get a clean 01 frame im going to swap my 04 frame is there anything to watch out for any advice is appreciated... like will my subframe on my 04 fit the 01 .....and so on
I dont see why it wouldent!
The subframes are different but it will fit, the only thing being the rear shock reservoir, it was frame attached on the 01s and integral in 02 and after........
Everything will be the same except the location of the CDI and voltage regulator..........
wouldn't the frame be the same or will i have to get new shock for the rear and wouldn't the cdi locate the same under the seat since i am using 04 plastics and cdi and the voltage reg is under the seat also....
i dont see any difference in the frames
ok cool i got a complete 04 frame but the rear lower a arm mount point is bent so i got the 04 sub frame so i should be good to go thanks you for the help
