I have fuel leaking out of the float bowl drain tubes, I'm told that my float needle valve is stuck open, I've tryed putting my raptor on its ass and then letting it fall onto the front suspension. I've tryed blowing air into the fuel inlet and the drain tubes, I've also sprayed carb & choke cleaner into it, it reduced the flow of leaking fuel but did not stop it. I have thought of taking the float bowl off but the screws are hard to get to. Does it sound like float or needle valve adjustment problem instead of a needle stuck open by sand or varnish from bad gas? Any other suggestions?
