I bought an 01 raptor 660, had carb issues. Previous owner attempted to work on it, set the air/fuel way to deep. I went to back it out and the needle snapped off and was stuck in the carb. I messed with it for hours till I finally got it out. Problem is the hole is noticeably bigger then the other side. Idk if both sides are the same bore or if I screwed it up trying to get it out. I can always buy a used housing if need be. Just want to be sure that I need to. Or if there is a fix for it. Or maybe it's just fine. Idk. Here's a pic of both bores. Also a pic of the damage from me picking at it. Thanks in advance!
138550
138547
138548
Just put a new pilot screw in it and set it maybe 1/4 turn less than the un-damaged side.
Ride it!
Discussion Starter #3
Man if that's the case thatd be sick! I got the vitos screws coming in, the ones you can adjust with the carb mounted. Itl make it easier if it actually works
I've got them and love them... you're good to go. The screw is just a valve that reduces flow through the pilot jet - as long as it closes when all the way in (gently!) then you will be able to use it still, just less open cuz the hole is bigger now..
