I was riding today for a while with no problems until I stopped and shut it off. By the way its an 06 700. I went to start it and it turned over but would not run. I took the dipstick out and oil came gushing out. I googled this and it said possible fuel in the oil, it smelled kinda like fuel. So i drained all the oil and changed it and it started up. I don't want to ride it until I get this problem fixed cause I have a feeling it will do it again. My trinity stage IV fuel controller has been installed for 5 days. It runs like a raped ape and this is the only problem I've had.
Discussion Starter · #2 ·
any help would be appreciated!
you should call trinity!! your bike cant be the first to have this problem:( they should know whats up8)
I just took it to the shop, hopefully they can figure it out without draining my wallet.
Ridin High.....
how long do you wait after shutting the raptor off to check the dipstick?
Well I stop or a cig break so it was probably about 10 minutes before I tried to start it back up then another 5 until I unscrewed the dipstick. Its all good now, just got it back from the shop, he adjusted the valves and fuel controller. Even fixed my broken reverse switch for free. I was getting tired of having to worry about dropping it in reverse while going forward which I did a couple times.
