I've read every post on the subject and I've had the carbs out at least 50 times, I am not joking.
I have never gotten this quad to run since the day I got it , about six months ago so it just sits.
I got some spare time today and took out the carbs and adjusted the "tangs" about five times. either trying to keep the bike running.(it starts runs Ok with the choke on then dies and wont start , I guess it floods itself out.)
OR to get it to start at all, (adjust the tangs "too low" and no fuel gets in so no start)
It seems to me there is no sweet spot, either it leaks or no start, no matter how little I bend the "tangs" it still does either one of those.
Quotes from RF I think willy or maniac:
"The ONLY way fuel gets into the bowl is through the float valve. If the bowl is overflowing, the ONLY possibilities are:
1) Leaking float valve - dirty, damaged rubber tip on float needle, or scratch on float seat face"
NO Just replaced part of rebuild kit.
2) Leaking float valve seat o-ring - cracked, worn, or debris stuck under it prior to tightening
3) Float adjusted too high - bend the tang to set proper height
Like I said above....
4) Float stuck - check alignment of float on mounting pin
NO
5) Damaged float - crack/leak allows fuel to get inside float which prevents it from floating on top of fuel in bowl"
NO, tested in water. they sure do float...
IS THERE ANYTHING ELSE TO LOOK FOR???? I'M ABOUT TO BURN IT TO THE GROUND WITH ALL THE GAS THAT'S LEAKING OUT.
NO
